high coolant temp when idling at uneven surface.
Ramon Triton
Mabalacat
strange, i parked my 1999 expedition on an uneven surface (banked 20 degrees left) and after a while of idling the temperature went up close to H and oil temp hot lamp went on.
didn't panic as i know the ford expedition is smart enough to do cylinder deactivation to cool engine in case of cooling system failure.
i moved to an even surface and shutoff engine. opened hood, coolant in reservoir was slowly boiling.
waited five minutes, restarted and temp was back normal.
continued journey with temp in normal range. no power loss, no knocking.
my theory is hot coolant in the reservoir touched the cap (because of bank angle) and might have caused cap to expand a bit and let air in or out hence the boilover.
coolant levels were normal last i checked, will check again in the morning.
JamaicaJoe
Oviedo FL
Air bubble in the cooling system? When you banked, the bubble went to the high side cylinder head?
Sent from my SM-T350 using Tapatalk
R
Ramon Triton
Mabalacat
error sounds right.
just checked coolant level after engine cooled down. it is at normal levels and is clean and clear.
ahhh just another fun day of truckin'
R
Ramon Triton
Mabalacat
something about being parked on a left bank is affecting the coolant system.
happened again today, less than 8 degree left bank, parked idling and coolant went up to 112 deg C (via bluedriver live data).
normal coolant idle temp is 99 to 103 and this truck idles for 20 to 30 mins regularly on our multiple stop trips with no issue, as long as it's a flat surface.
intake air temp at 55 deg C. Ambient 31 deg C.
still baffled, current theory i have is hot coolant touching coolant cap somehow allows some air to get in but there should be positive pressure so even that's still kinda iffy.
coolant levels normal and it's clean.
JamaicaJoe
Oviedo FL
Air bubble in system, radiator core blocked internally on one side, pump belt slipping, hose pinching .
Hamfisted
Ft Lauderdale
Is it the original radiator in the Expy ? If it is I'd be looking at getting a new radiator.
R
Ramon Triton
Mabalacat
original from 1999.
air, that would explain it.
doesn't it self vent any air as coolant circulates though?
will a coolant drain/refill remove the air?
ExplorerTom
Colorado
When you say “banked left”, are you saying that the driver side is high?
i too think it’s air but can’t explain why.
And coolant change could solve the problem- as long as you properly burp the system.
Hamfisted
Ft Lauderdale
If coolant is flowing through the radiator in a normal flow, it will automatically de-gas when it flows to the coolant reservoir tank. If there is blockage in the radiator, interfering with the normal flow, then you are not getting the normal de-gas flow the system was designed with. I would replace the radiator. A simple coolant flush is not going to fix the issue.
R
Ramon Triton
Mabalacat
banked to the left i mean driver side (left hand drive) is lower than right side.
will change coolant along with other fluids in about 400 mi, in the meantime will just avoid idling in surfaces banked to the left.
will do a radiator replacement if flush and fill doesn't remedy it.
mnachreiner86
Missouri
Just burp the system first and see if that solves your problem. No need to change the coolant. Start with the simplest/cheapest thing first.
