How hard is it to find parking?
Vicious
California
How difficult is it to find a parking space that will fit one of these behemoths? I've got a small space in an underground garage and am wondering if I will need to crawl out the lift gate :)
Does the parking assist make it easier to fit into smaller parking spaces?
doktoroktobor
Brooklyn, NY
I park in Brooklyn and Manhattan and I haven't had an issue. The parking assist is pretty great and I use it all the time, but if the spot is too tight you'll have to do it yourself.
Deadman
Wisconsin
I've yet to park mine in any parking lot of any sort..... The benefits of rural living! :)
Shutterbug57
Ohio
I have had mine only a few days, but have been in several parking lots including downtown Cincinnati today. I have not had any problems. Just park it in the middle of your spot and avoid parking next to line hogs.
Shutterbug57
Ohio
Usually the bigger concern is clearance in parking garages.
Yeah, knowing your height, sans people, is a must. I used a 4’ level on the highest point (middle of front crossbar) and, making sure the level is level, measured from the underside of the level to the floor. I am at 6’5” and change. I use 6’6” as my height and put a sticker with the height inside the 12 volt cover on the dash. Then you need to decide your tolerance for clearance. I have parked fine in a posted 6’7” garage, but keep your eyes peeled.
Shutterbug57
Ohio
The 360* camera makes parking a TON easier if you aren't sure about your placement in the lines...... Love mine.
The 360* package would be nice, but, if you don’t have it, small stick on circle mirrors will also show you the lines.
Jace
Utah
I've seen a few parking garages be a little off on their measurements, so having that extra inch or two sure helps!
I had 9" lift on my truck years ago and I cut off the antenna just above the height of the cab :biggrin:
aggiegrad05
North Texas
I loved this on my F150...the antenna extended about an inch above the cab, so as long as my antenna cleared I was good. If my antenna scraped, it knew I had a decision to make based on how much I wanted to park in that garage, how late I was running, and how much my insurance deductible was.
TobyU
Ohio
We had height issues in DC in 2000 EXP XLT 4wd. The first two it would not fit in.
I have a lifted Durango on a metric tire that is just a hair over a 38 inch tire. It has 5.5 Up Country susp and 6 inch body lift. I couldn't fit it through the local Mike's Car Wash until I took the luggage rack bars off. Then it fit fine.
