How much voltage inside to the spark plug.How much resistance coil
saudi
Good morning
Question
How much voltage going to the spark plug.
Exp2012
ezeq
canada
It would be better to let us know the year and model of your expedition so that others might join in regarding about your trouble and let you know how to fix it. You need to let us know if there are trouble codes showing.
Now , since you know the word "resistance", it might be a good idea for you to use a DMM, do a "BENCH TEST", check the primary coil resistance and the secondary resistance for you to be able to see the readings itself.
ABU FARES saudi
saudi
Thank my friend
I have expedetion 2012
Also my English is weak... sory
I will explain to you the problem
I have code
p300
P301
P303
I Replaced all spark plug
Also i switch coil
No. 3 to No. 5
to know the problem from spark plug or coil but The same problem.
I just want to know How much the resistance fo coil and the volt
Thanks
تم الإرسال من جهازي SM-N9005
ezeq
canada
No problem my friend, it is a misfire on those cylinders, might be a bad plugs, or the coip itself, since you replaced the plugs then it might be the coil.
Might be a good idea to take it to the dealer if it still has warranty.
