How to install subs
Tuffy
Tampa/Auburn
Has anyone found a guide on how to do this? My friend and I were looking around trying to find where the wires go from the engine or whatever to inside of the car. I am trying to install my subs and I don't have a guide or anything.
WHOISMOOTOO
Dallas, TX
Crutchfield.com look in there knowledge base and if you want videos look on youtube there are 1000's of them
stang99gtv8
Oh
My sub setup that is now running as the juice for my power inverter is running to my battery through the door wiring grommet and into the fender well. If you can't find a hole in the firewall or don't want to drill a hole and such, it's one way to avoid all that if you don't mind fishing a wire hanger through the space.
panda24619
San Diego
luckly you have the 1st gen. theres a rubber groment on the drivers side of the firewall. thats where all my wires run threw. thats where you should put the power wire. then find a good place for a ground close to your amp and run your amp remote wire and rcas. and to wire the subs use this. http://www.the12volt.com/caraudio/woofer_configurations.asp
it shows you every possible way to wire your subs with 1 amp. if you have a 2 channel then just 1 sub 1 amp. its easy to figure out. it helped me.
