Expedition
The housings themselves fit onto the truck, with no modification. The Brake/Turn Signal socket goes into the Brake/Turn Signal hole no problem. But the reverse socket is to big to fit into the the 07+ light. You can either go to an auto parts store and buy the correct socket (I think it's a 941) and splice it into the reverse wiring. Or you can do just like I did and enlarge the hole. The way you do it is your choice. The pics below are from the first lights I did, I used a dremel and saw. The second lights I just heated up a knife and cut out what wasn't needed. Here are the pics.
