How to remove/install fuel pump in 01 Expy
ELVATO
Orlando, FL
These are the instructions I have on how to remove/install a fuel pump from a 2001 Expedition. It should be about the same as 97-02, but I'm not guaranteeing anything.
Again, this is for educational purposes only, so I'm not responsible if you break something.
Removing
WARNING: WHEN DRAINING FUEL FROM THE FUEL TANK, KEEP SPARKS, SMOKING MATERIALS, AND OPEN FLAMES AWAY FROM THE VEHICLE.
WARNING: THE FUEL SYSTEM CONTAINS PRESSURIZED FUEL AFTER THE VEHICLE IS SHUT DOWN AND WILL MAINTAIN THE PRESSURE FOR A LONG PERIOD OF TIME.
1. Relieve the fuel pressure.
2. Disconnect the battery ground cable.
3. Raise and support the vehicle.
4. Disconnect the fuel tank filler pipe hose (9047) from the fuel tank (9002).
5. Drain the fuel from the fuel tank (9002).
6. Disconnect the fuel tank vent tube (9A228) from fuel tank filler pipe (9034).
7. Disconnect the fuel pump electrical connector.
8. If equipped, remove fuel tank skid plate.
a. Remove the five fuel tank skid plate bolts.​
b. Lower the fuel tank skid plate.​
9. Position a suitable jack under the fuel tank (9002).
10. Remove the front fuel tank support strap (9092).
a. Remove the two bolts.​
b. Remove the front fuel tank support strap (9092).​
11. Remove the rear fuel tank support strap (9092).
a. Remove the three bolts.​
b. Remove the rear fuel tank support strap.​
12. Partially lower the fuel tank and disconnect the two EVAP emissions hoses.
13. Remove the two safety clips from the fuel lines.
14. Disconnect the fuel lines from the fuel pump (9350).
a. Install and push the (A) fuel line disconnect tool into the (B) female fitting.​
b. Separate the male and female fitting.​
15. Remove the fuel tank.
16. Remove the fuel pump.
a. Remove the fuel pump locking retaining ring (9C385).​
b. Remove the fuel pump and discard the O-ring.​
ELVATO
ELVATO
Orlando, FL
I'll try to post the install sometime tomorrow. :)
LightningExpo
thanks for the post, just went through the car and it turned out that it was a fuse.. crazy how the car was doing exactly the same thing as when the pump went out the first time.
ELVATO
ELVATO
Orlando, FL
Haha, at least you didn't realise this after dropping the tank, and spending money on a new pump. :D I'll still try to post the install today. No sense having removal instructions if you don't know how to put it it back on :)
badbolr
