I want Fog Lights!
JoeExpedition
Western Mass
I have a 98 Expedition XLT, with NO fog lights.
Right now the truck has the black plastic inserts where the fog lights go.
But I discovered that I can pull the light switch out when its at the headlamp position. I believe this is the fog light switch. Am I right? It automatically retracts when the switch is rotated to parking lamp and off.
I looked under the truck where the fog lights would go. It seems that there is already wiring there waiting for fog lights. Each side has a lead with a plastic (and rubber gasketed) plug with two leads.
I tried to check voltage on it with the switch on, but got nothing. It could be due to light surface corrosion of the past 9 years.
Does anyone know about this? Does it sound like I can just throw a pair of lights in, plug them in and go?
(Hoping for some Yes answers...)
Joe
green03
College Station, TX
at least on mine pulling the switch out turns on the fog lights. You may need to find the fuse location as you may need to put a fuse in there because the factory had to save the 2 cents on the fuse since your truck didn't have that option.
Matt
pronstar
Long Beach, CA
You need a new switch. The standard switch mimicks the motion of the fog light switch, but it doesn't have the same internals.
The rest should work just fine by using the existing wires. I've reads a few posts on other forums that others have done this and it worked great.
J
JoeExpedition
Western Mass
pronstar, thanks for the reply.
I will see if I can try that out. I wonder why the standard switch mimics the motion of the fog light switch...
But it gives me hope!
I will post the results as I go.
Have you heard of any need to switch out the relay too?
Joe
pronstar
Long Beach, CA
I believe you just hook it all up...is there a shared relay in there already?
Sorry I'm not much help...I'm just going on what I read from others.
But everyone says that on the old bodystyle Expy (like ours) all you do is replace the switch and use the existing wires...and presto, it works.
J
JoeExpedition
Western Mass
Thank you pronstar...please keep checking in on this post...you have given useful info.
Your last post sounds like good news to me, I have my fingers crossed...
I ordered the switch and lamps/brackets. Guess how much the new switch costs... guess quick...
The new switch is about $175. The lights are $106 for left and $102 for right.
I once heard you have to be careful for what you wish for, because you might just get it ... (and pay $400 or so for fog lights!)
pronstar
Long Beach, CA
I looked into adding them as well, but couldn't justify the cost.
I found the lights for about $60 each on E-bay a while back, but the left one was always a little more expensive for some reason...
At any rate, I never bothered to look at the switch prices, because I was too cheap to even fork over the buck-twenty for the lights.
Sounds like we all should be selling switches!
dubedition2003
North Shore, MA.
On my old 97' expy it did not come with fog lights, so I purchased my fog lights from E-Bay also for about $90 for a pair and it looks much better then the stock OEM it had a diamond pattern to it.
Come to realized the hard way that I needed a new switch, because the one that was in my 97' was just a dummy with the pull thingy.
Called the dealer and found out they had to send it out somewhere to get it done because they don't do the wiring the harness at the shop.
So I went to AUTOZONE and bought a fog light relay kit and wired it up to my corner lightsmyself. VERY SIMPLE TO DO. All the instruction came with the kit. Cost about $15 for the fog light wire kit.
dubedition2003
North Shore, MA.
No, I used a rocket switch and mounted onto the dash right beside my steering wheel. I had to wire one postive to the battery terminal and one other postive to the corner lights (this is how you would be juice to the fog lights,) then grounded the ground wires onto the body of the truck under the hood.
edyk1986
