Identify button on dash?
2020-MAX-Limited
Colorado USA
Can't find this button (circled in yellow) in the manual. It is a simple push button just above the instrument panel brightness adjustment.
turtle019
MI
Aftermarket. I take it you got your truck used? Anything obvious the previous owner added like lights?
Yupster Dog
Moderator
Not another mystery button. I'm still waiting to see what the buttons did on the first two threads about a mystery buttons to get solved.
They seem to show up out west, first one was in Utah and the other in Arizona.
Must be remnates from Roswell.
Hamfisted
Ft Lauderdale
Drive it around the block at night and hit the button and see if any lights come on or off. Or speedometer dies or interior lights go out even with the door open.
dcsang
Is that a maintained button or momentary button?
If there's nothing audible or visual (at night as suggested) that can be detected then prepare to trace wires if you're curious enough. Since 'ejector seat' and 'plaid mode' were taken I'll suggest aftermarket lighting (light bar?) that may have been removed.
99WhiteC5Coupe
I have a 2015 Ford Expedition Limited 4x4, purchased new.
There is no button above the panel brightness adjustment rocker switch.
99WhiteC5Coupe
I was more worried that someone would post again, asking what is the best oil filter to use.........
2020-MAX-Limited
2020-MAX-Limited
Colorado USA
Is that a maintained button or momentary button? If there's nothing audible or visual (at night as suggested) that can be detected then prepare to trace wires if you're curious enough. Since 'ejector seat' and 'plaid mode' were taken I'll suggest aftermarket lighting (light bar?) that may have been removed.
It's momentary, just pushes in and pops out, no clicks that would indicate something is engaged or released. I purchased used, and the CARFAX indicated government use, possibly law enforcement, so I like your suggestion about add-on lighting. There are some holes drilled in the plastic cladding near the third row that could have been "police lights" I guess. There's also several holes on the passenger side of the center console that could have been a mounting location for radio(s).
