rtbrjason
Started noticing this issue after a bunch of work, so not sure if it is related or just something else that popped up.
Car idles fine in Park. When in drive and stopped with foot on brake, I'm getting a bit of a rough idle and barely noticeable surging. The rpms aren't surging so much, it's more a surge of poor idle. Once shifted into park it is fine.
I cleaned EGR/IAC. In the case of the IAC, I dropped the new gasket down into engine abyss and had to reuse the old. This could be the whole issues I guess. I replaced all plugs/cops. PCV valve replaced. TB removed and fully cleaned. Upper intake was fully cleaned at that time. Most of the vacuum line system has been replaced at this point as well as I found several small leaks or shot pieces of tubing.
The only similar post I've found was on the other Ford forum, and for a Bronco with a 5.8. He was having the same issues and solved it with a fuel pressure regulator. Anyone else have this issue and solve it? Would that be a good place to start? I don't have a fuel pressure gauge to check it with unfortunately.
