Installed Cold Air Intake, Runs Lean?
TCo22
Florida
I installed a Cold Air Intake on my 03 5.4Ltr & now it is running lean! It hesitates & acts as if it has a miss in 1 of the cylinders! Any help on how to fix this with out removing the Cold Air Intake would be Great!
Rockunlimited2
Omaha
Remove the batt cables overnight so the comp will reset to learn the new air to fuel ratio. Then make sure you did not over oil the cai. If you did, clean the maf with maf cleaner not parts cleaner and don't touch it just spray it. Should be good after that. Try the batt disconnect first before messing with the maf.
Newport News, VA
make sure that it hasnt come loose. mine did the same thing and was getting OUTSTANDING mpg's...it was sucking in so much air!!! but when i would decelerate and stop it would do this. come to find out it had come loose. tightened up...fixed.
T
TCo22
Florida
I had already disconnected the battery, but only for about 20 minutes! I am guessing that it needs more time to clear the computer? Also I did not oil the CAI! What part of the CAI is to be oiled? I will also clean the MAF today!
T
TCo22
Florida
bhsoulja, I apologize! Wasn't ignoring you. I must have been typing my response to the first reply when yours posted & didn't see it! I have infact checked for leaks & unfortunately it's not that! Thanks!
markanthony
Bountiful
TCo22;51649Also I did not oil the CAI! What part of the CAI is to be oiled?[/QUOTE said:
you oil the air filter element. if it is K&N their is a air filter recharge kit that has a cleaner spray and and oil spray. I think most filter come shipped with oil and done. install and run...
On the computer. it takes about 3 to 6 hours to completely reset. I am not sure why. but that is how it works...
T
TCo22
Florida
OK, Disconnecting the Battery is not working! I had it disconnected for 10 hours last night, When I reconnected this morning I get the same thing. Acts as if it has a miss. Any other Ideas? if not I am just going to put the stock intake back on!
panda24619
San Diego
make sure everything is connected properly and clean all sensors. the maf and check all vacuum lines.
markanthony
Bountiful
Pull the air filter off and start it. Does it do it then or not.. if it does then their is something else. Is the vaccum line hooked up to proper locations...
This may sound odd... is it the right intake... it could be wrong one and not work right.
markanthony
Bountiful
Sorry.. a little forgetfull. Have we change out the plugs and coils.. all of them or a few.could be the fact of a random coil that may not have been replaced. Stupid coils.. this is why i changed all of mine out
T
TCo22
Florida
Found a Broken Vacuum Line, Repaired it & still have same hesitation! I am resetting the computer one more time & we'll see what happens!
