Installed Raptor lights last week
armoredsaint
Ohio
Got it from F150led, wanted the 3 light but our grilles don't have the middle cutout so i got the four, it's not bad - but I would like to dim it down just a bit possibly. Looks better in person than pics because the camera gives that halo effect. I wired it to the fogs for control, I really wanted to wire it to the side marker lights but that was a lot more difficult to access.
SnodB
Dulles, VA
Really nice look. Could you share the part number or link on F150led. Was it complicated to wire into the fogs? Any pics of how they mount to grill or the wiring at fogs? If not, no worries but thought I would ask. Enjoy!!
RABAYL01
United States
Nicely done. So to turn these on during the day, do you still use the auto headlight function? I thought to get the fogs on during the day you turn on the parking lamps manually
armoredsaint
armoredsaint
Ohio
it was very easy about 2/10 on difficulty, the fogs are in the inner front wheel well and tap it into there, there's a youtube video but it's all F150's but basically the same install except the wiring is different especially if you have the 2022+ and LEDs
armoredsaint
armoredsaint
Ohio
it'll only turn on if i have the fogs on, the preferred method would be the side marker lights but access was difficult. the fog was simple to tap into and just button everything up with zip-ties.
SnodB
Dulles, VA
Thanks for the additional info and the link to F150leds - will definitely give it a a closer work. Great job on your install!
Bub_28
Tennessee
My Expedition is 2024. I hooked the positve to the Yellow with Blue Stripe. I couldn't find a ground that would work so I tapped into the ground on the Fog Lights. The Raptor lights work with the parking lights. The plug is kind of hard to find. It doesn't have clip to hold it on, just have to pull it.
Langer
Chicago
Just to confirm, you used the 2024-26 f-150 lights for your 2019?
