Jason Mankey
My 2010 has a weird issue. My Intermittent wipers work ramdomly.
My low constant and high constant wiper work perfectly. But on intermittent speed its all messed up. There are 5 intermittent speeds according to the turn signal lever. The top 2 intermittent speed run the wipers in slow constant speed. The lower or longer 3 speeds act the same........ramdom wipes at who knows when.
I am assuming my motor and linkage are not to blame since it runs fine in slow constant and fast constant.
Back in high school (many moons ago) I had a car that had a specific intermittent relay and it needed changed. Looks like this has a single relay for all speeds.
Is this what a bad relay does? Do I need to look at replacing that turn signal switch? Is there anything else that would cause these symptoms?
