Is my new compressor bad from the part store Low/High same pressure
grey169
wisconsin
Friday while driving down the road I had a squeal and a shutdown of the engine. The compressor bearing had locked up and shredded the serpentine belt.
After a tow to the house I replaced the belt and the compressor (another nightmare) and she ran like a top.
I did the tow errand that I needed and began the process of adding fluid.
I did a vacuum and it held that vacuum for over an hour. I added R134a with the truck running, AC on High and waited. Low pressure increased to 85. I watched the high side slowly creep up to 85 as well.
The high side valve is shut off and only the low side is open.
Does this mean that the compressor that I just got (and spend 5 hours replacing egads what a PITA) is bad?
Last year I replaced the condenser and expansion valve (for the rear) and the dryer and it blew extremely cold so I know that system is otherwise working.
stamp11127
Temple, Georgia
Did you pull the orifice tube and check for debris before swapping compressors? The bearing or the compressor may have locked up. If the orifice tube is loaded with metal it was the compressor that seized.
Compressor warranty usually stipulates that the accumulator or receiver dried needs to be changed with the compressor to be valid.
Pressure readings seem to be static values - makesure the compressor is running.
G
grey169
wisconsin
The new compressor is not running. The electrical connection is connected. Once the low side has enough pressure the compressor should turn on, correct? It should be 12 V at the connector?
stamp11127
Temple, Georgia
Correct 12 volts at the compressor. Low side switch should close with that high of pressure. You can jump the low side switch if you don't have 12 volts at the compressor.
Did you add pag oil to the compressor?
G
grey169
wisconsin
I added 3 more oz. It came with 3 already.
I will check low pressure switch. Is that by the condensor?
stamp11127
Temple, Georgia
High pressure switch is usually by the condenser, low pressure is either in the line going from the evap to the compressor or in the accumulator. Of course it will be in a position to almost not see it.
gixer2000
Retrofit or Bust
Massachusetts
Have you checked the fuses? Its ppretty common for the fuse to blow if the clutch burns up
G
grey169
wisconsin
I have not checked fuses. I will do that tonight if I am able. I was able to find the low pressure switch. It has 12VDC on the one wire. I jumpered it and still have no engagement of the clutch.
stamp11127
Temple, Georgia
With the low pressure switch jumped, see if you have 12 volts at the connector for the compressor. If you do then check the compressor clutch coil for resistance using a meter.
I just had the same occur, my expy sat and didn’t get driven for 7 days. I started it up and heard a screaming belt..... rebuild compressors don’t seem to work well.
G
grey169
wisconsin
Sorry for the delay. It has been a really long couple of weeks.
I have the switch jumpered. It has 12VDC on one side so I have voltage there.
I have measured voltage at the compressor and I have .2VDC so I would guess that is just noise.
The compressor has 4 ohms across the pins so I think that is good as well.
Is there a wiring diagram that is available so I can trace it? Where does the voltage go from the switch to get to the compressor?
stamp11127
Temple, Georgia
look at these:
  • 2003.1.pdf
  • 2003.2.pdf
  • 2003.3.pdf
  • 2003.4.pdf
G
grey169
wisconsin
To close this thread, the AC is now working. I though I had checked the fuse but it was blown. Everything appears to be working and I have cold AC now.
Thanks to everyone who has such great help!
To recap.
A bearing in the pulley for the compressor locked up and destroyed the serpentine belt.
Replaced compressor (a nightmare in itself)
CHECK FUSES!!!!!
Trouble shooting was good to understand what is going on in the system.
Filled with proper amount of R132a. Cold AC!
