HTR21
I'm willing to drive.
Is there a Ford Service Center that doesn't suck donkey balls?
No. They're all technicians, not mechanics and most of them are not particularly good technicians. However, even if you get a highly skilled technician, you aren't likely to get their best. Techs usually get paid flat rate, which means they get paid based on the suggested labor time for a particular job, rather than the actual time it takes to do the job. That means they are incentivized to do fast work, not quality work. And if they get paid hourly instead, they are often grossly underpaid. I met a guy last month that was getting paid $7.25/hour; he was in the midst of replacing a transmission. If you're getting warranty work done, there's even more incentive to get it done quickly as they typically get paid less than they do for cash pay work. Moreover, the dealership doesn't get paid squat unless they replace a warranty item so they would rather replace 5 things that may or may not have anything to do with your specific problem than spend extra man hours trying to diagnose a complex issue. To top it all off, dealerships always charge more than the going rate at a good independent shop - both in terms of hourly rate and hours billed for a particular job. Look at the guy in the spark/COP replacement thread; they're hitting him for 4 hours for a job that even a complete novice can do in 2. If you're under warranty or have a problem that specifically requires a dealer (e.g. you need something reprogrammed using a tool specific to Fords that no independent shop wants to invest in) then by all means hit the dealer. Otherwise, shop around for a good independent mechanic. You'll get better service and for less money. That's my 2 cents anyway.
