st381183
No critter that I know of. Just the dry NM heat eats everything. I barely noticed the dry rot when I started this project.
They must of shortened the battery brackets or the 18's hoods are higher than the 17's. Because the battery bracket I recieved was to tall.
Once your done drilling the hole for the second bolt for the bracket, I drilled another hole for the wiring harness clip to go back into in front of the bracket. Makes it a clean looking install.Correct. The Battery bracket will not work on the 15-17, but will on the 18+.
Vinny is TOP notch. Great guy!
He sent me the kit, with a discount to convert my kit from the 17 to the Battery mount to fit the 20. Going to get it installed this weekend.
Sent from my iPad using Tapatalk Pro
JLT sends the firewall mounting kit with with the 2018+ Expedition catch cans. Hopefully, this will change going forward as Vinny asked for me to confirm fitment. I sent him the same pics I posted here. If in doubt just order the F150 kit which will come with longer hoses.
