Probably battery related. Every time this happens to my 16 I either swap fobs or change batteries. Works every time.Joe J, Did you ever find out what was causing the problem? My 2015 has the same issue although it is intermittent.
Thanks!
Thanks!
Figured out what was wrong, so I'm posting this in case anyone else runs into it. Turns out something had gone wrong with my shifter, so the truck always thought it was in neutral when I turned the truck off. I had the dealer replace the shifter and the problem is all solved now. Remote start works properly now and the frickin' dinger is gone now tooAlso discovered a few other things that work now that I didn't realize weren't working, such as the driver seat automatically sliding back a bit when you turn off the truck. Service department also said that it caused a parasitic draw on the battery when the truck was off. Never led to any problems that could tell but who knows.
Feels like a brand new truck now![]()
