LastExpo2000
What's the largest and widest tire that can go on a 17x9 rim
lastExpo, there are a few different ideas here, so, follow me on this.
If you want to be garanteed no rubbing at all, then 285/70R17's is about as big as you can go with no suspension modifications.
Now, depending on the offset/backspacing of the rims, you can possibly get away with 295/70R17's. Some members have had good luck with this, some have rubbing issues.
If you just want to stick on the road and don't plan on twisting the truck up at all, then you can fit 315/70R17's. But, with this tire setup, I can garantee that you will end up with rubbing even doing simple things like going out of a driveway with a large curb at the end or trying to make a sharp turn on to a road that is starting to head up a hill.
Now, keep in mind that I am assuming rubbing under the most extreme of conditions (ie, a wheel in the air with 2 other tires pushed into the body at the worst position of the steering wheel) with no modifications. If you don't drive your truck that way, then the options open up slightly. If you are willing to make some minor modifications, the options also open up.
What are you wanting and what are you willing to do to get it?
Yes, the general rule of thumb is no wider than 4.5"s wider than your rim(i.e. 12.5" on a 8" rim or 13.5" on your 9" rim)Could I run 35x12.50's or something equivalent to that on 17x9's?
Ask me how I know....
