Hello again. 2007 Lincoln Navigator 160k. Noticed small spots of gas on the ground and of course the smell. Found out it is a leaking sending unit from the gas tank. The only problem I have is it does sometimes have hard starting. Like it takes more then a few seconds to start her up. My question is should I replace the whole sending unit or just the seal itself. Not sure if the hard starting is caused by air leaking in or the fuel pump Itself going bad. Also my other question is I do like to stay with oem parts but I'm only keeping this vehicle for 2 more years. What's the best aftermarket pump to go with? Thanks in advance
