tmac04EB
I have a faulty tire pressure sensor that's driving me nuts. Is it possible to just disable it so I stop getting the warning on my message center.
i wouldnt advise it then you'll never know when you actually have low pressure...how do you know its faulty? are you taiking it to the recommended psi and light still on? go a couple pass the psi and see if that kills it...make sure all tires are good and with you being in WA...its getting cold and that does play with your psi...after that look at getting new sensors...then have them reset at your local shop if you dont want to go to dealership
Try a nitrogen fill in your tires, it is more stable than compressed air. I ran 35lbs all summer then it cooled off recently, my light was illuminated on the cold mornings, loaded them with 37lbs of nitrogen and no more light, I think you will see the difference.
