Originally posted by eddie
will the truck bounce alot if i cut the springs
Absolutely it will. On a vehicle of this weight, cutting anything off, will directly effect the ride (negatively in my mind). By the time you cut enough off to lower the ride, a large percentage of that spring is gone. The weight of the vehicle is the same, so, it will be some X% "Bouncier", probably exponential in my mind.
Someone asked why would you do this? To make the thing handle better in the turns, that is why.
That is also why I liked my Range Rover air suspension. Once you were at 35 for 30 or 40 seconds or more, the Rover would lower 1 1/2 inches. Come up to a stoplight, and it stays lowered, unless you are under 30 Mph for about 2 minutes, I think.
Go offroad, and raise the thing (2" or so). Then in offroad mode, if a tire spins, it thinks you are on a log or a rock, so it raises it another 1/12 or 2" I forget.
Go out to a nice restaurant, and want to make it easy for people to get out? Put er in Park, hit the access button, and wham, you are sitting on the bump stops, hammered.
Really cool.
