Dr0idattack
When towing I run my LT in the 70s; running at 44 would seem too low. Also what WDH did you go with?
My WDH is the Blue Ox, 1000 lb bars. The trailer salesman set me up with 750 lb bars originally based on the dry tongue weight - I upgraded because my measurements were always closer to 900 lbs.When towing I run my LT in the 70s; running at 44 would seem too low. Also what WDH did you go with?
I switched from P to LTs on my 11. When NOT towing the tires are set to 35. Ride was fine. First time towing my 6500lb TT with the LTs, I inflated the rears to 50psi (80psi max). HUGE improvement over the P tires with respect to how well the truck handles cross winds and passing semis. When I used to tow with the Ps, I'd inflate them to 45psi (51psi max). I also added Sumo Springs coil "spacers" in the rear. The truck doesn't squat as much now. I use an Equalizer brand WDH. I never had issues with actual sway, but a semi would push the back of my truck around. No longer.
