docraymund
Good day ! Just want to ask if an engine misfire can be fixed without the use of code readers and how do you do it? Also can a faulty ignition switch cause misfire? Thanks.
Hi. New to the site, but really like the threads. I have a 2000 4.6l 4x4 Exp. I began to have misfire problems about two years ago (approx 95k miles). Ran rough for a good amount of time before the engine light came on (code available)-turned out to be a coil. About a month later same thing with another coil, so I got frustrated and just replaced all coils and plugs. Ran well for about a year, and then same mis-fire condition. I bough a shop manual from LMC and used the specified Ohm reading ranges to test all the coils- turns out that #1 was slightly below the others-but within the specified ranges. I replaced this one with a good coil left over from previous swap outs and ran some Sea Foam through the motor-checkd all filters- cleaned MAF sensor and this worked for a while (few months) now it runs rough on acceleration.
The manual gives a trouble shooting checklist in sequence- its saying to check Throttle Position Sensor (TPS) and Exhaust Gas Recycler (EGR) sensor. I feel like Im chasing my tail...any suggestions? Acceleration is really rough on wet days and when engine is cold-seems to get better as operating temp comes up. Also, I've noticed a slight hiss coming from passenger side engine compartment-maybe an exhaust system leak?
Any input appreciated.
I had the same issue with misfire again and this time it was finally solved. Turns out I needed a reprogram from the ford dealer with the most recent updates. Drive much different/better than before. And it didn't cost much at all.
Sent from my myTouch_4G_Slide using Tapatalk 2
