Misfiring again, full tune-up?!
Drac Morbis
the US south
It was misfiring on cylinder 5 some time ago. A new spark plug, coil, and injector cleaning fixed it. It ran like a race horse for months and months. Now it's misfiring on cylinder 3. The mechanic I use said he'll do a full tune-up this time, all new spark plugs, plus a new coil for number 3. And the usual other stuff.
Is this good? Do I need all the coils replaced?
I don't know anything about vehicles. lol
Thanks!
Gary Waugh
Princeton, TX
Make sure he does a compression test on all the cylinders first, you might have a failed head gasket or damaged valves on that cylinder, in which case new coils and plugs are a waste of time & money.
Drac Morbis
Drac Morbis
the US south
Thanks! Is that expensive? Or is it a standard test?
Gary Waugh
Princeton, TX
It’s not expensive, just a bit time consuming to remove the spark plugs and then measure the compression on each cylinder. Takes about an hour to run the test on all 8 cylinders. Once you know compression is good then he can look for other faults, but having good compression is the first thing you need to check.
Drac Morbis
Drac Morbis
the US south
Awesome, thanks! I'll be sure to mention it to him. :cool:
texasscot
Kerrville, TX
Thanks!
I think i've fixed my random misfire/rick condition problem by changing out the injectors. I'd tried cheap ones and got similar but different problems. Just put in the Motorcraft injectors and tested it this morning. It's now a sewing machine. My vehicle is at 295,000 miles. Maybe your injectors are bad. Test the key on fuel pressure at the rail and also at the pump. if the rail value drops quickly and the pump value doesn't, your injectors are probably dripping fuel causing misfires.
Drac Morbis
Drac Morbis
the US south
Thanks much! What about all new coils as well?
