MPG vs Cruise control report.
D
Deadman
Wisconsin
I just keep the 4A OFF to save the wear and tear..... Fuels an added bonus.
Plati
2014EL 5.4 transfer case (AWD capable)
I just drove 2200 miles interstate Wyoming to NY. Tested gas mileage as reported by the vehicle computer running in AWD or 2WD under various conditions, at speed. Sometimes I ran 6 hours or more or less and I switched back and forth from 2WD to AWD about 6 times.
Obviously hills not the same or wind or speed or fuel etc so a little sketchy. At no time did I find a big difference in MPG. I obtained 14.5 to 15.2 MPG depending on the run. It almost seemed like AWD might be giving me better MPG but not much if anything. As I headed east the speed limit goes from 80 to 65. Better MPG at 65.
Those new light truck tires seem to really hit my MPG.
I'll be putting my summer tires back on soon and will see if that gets me back to 17MPG
Dice Roll
Craps Table
New tires lower fuel mileage. More tread to flex. Usually see 5% reduction in mpg going from old worn tires to new ones.
D
Deadman
Wisconsin
Aggressive tires absolutly kill MPG. My buddy put some 8 plys on his 1/2 ton and it cut 3-4 mpg off. Be careful what you put on for tires. Some are crazy heavy and then the wind resistance is also a factor.
Plati
Yes. I like those tires! Those are the tires for ME
re: Lounge closing ... ABOUT TIME. Place was biZzaRe
mquick5
Buckeye Country
@MrSticker
Are you saying the older trucks like your 2014 have awd mode? Or are you calling 4A awd? I think it's sad the newer trucks dont have the 4A.
TobyU
Ohio
Only reason we post in lounge is it's the appropriate place for generic or non specific conversations.
Won't be much reason to be here if we can't discuss everything and enjoy killing time here.
Plati
@MrSticker
My 2014EL has 2WD 4A 4H 4L settings
My 2003XLT has 2WD A4WD 4H 4L settings
the 4A and the A4WD setting are the same .... and IMHO are AWD
but industry standard definitions are fuzzy on the meaning of 4WD & AWD, I guess maybe
I (luckily) have no idea what newer trucks have
thegerb50
