Teddy62
Forgive me. I tell long and detailed accounts.
I will try to be brief.
This is an 03 Eddie Bauer Expedition with 91,000+ miles.
Two weeks ago....my drivers window glass fell inside the door.
After mechanic set it back in place....it never sounded smooth running as before.
Then! The window would only go up a few inches after going down (power windows).
It will go down....no problem.....but only comes up a few inches. It will repeat flawlessly,
but will not go all the way up.
Next! After living with plastic on the window a week or so.....the 4x4 low and high dash
lights began blinking in sequence....3 blinks.....15 minutes later....3 blinks....repeatedly.
I know they simply mean "concern within that system" (from reading on internet).
At the same time! When using the door lock button on door......to lock all doors......
The drivers lock jumps up after 2 seconds! But if the key fob is used the drivers door
stays locked!
Also! In the past....when fob was used to lock the doors....second button pressing
would sound the horn (as confirmation the doors were locked). The horn no longer
sounds when fob is pressed a second time.
Seems coincidental that all the symptoms appeared at the same time.
There must be a common factor here some where.
Can anyone help me?
stays locked!
Can anyone help me?
