Multiple Systems "Not Available"
RNVXLT
DFW, Texas, USA
I have a 2018 XLT and recently I started getting notifications on the display of "Service Advance Trac" , "Hill Start Assist Not Available", "Pre-Collision Assist Not Available", "Drive Mode Selection Reduced due to System Fault" and "Park Assist Not Available" also the ABS light is on. This would happen intermittently, we would turn off the vehicle and turn it back on and all would be fine but now this does not help anymore. I've checked all the fuses, checked for corrosion on any of the ground connections, corrosion in the pins of the ABS harness and the harness itself for any cuts or chaffing and all seem fine.
Scan report says all wheel sensor are bad and comes up with code U0415-00 "invalid/corrupted data". I find it hard to believe all the sensors went bad at the same time. I did have to replace one rear tire due to a gash on it's sidewall, the Discount tire tech checked the other tires and said they didn't need replacing just yet. I moved the new tire from the rear to the front after doing some research the difference in tire thread height might confuse the speed sensors, I then drove a about 10 miles hoping for it to clear out but not yet. Hopefully after a few more days/miles.
Has anyone experienced this issue? any help would be much appreciated.
