My Expy acceleration video
toms89
technical advisor
MD
I uploaded a video I just shot tonight. I was holding camera so sorry about the quality and focus.
I was going up a slight incline and was initially on the side of the road so I hesitated for a moment until I was sure she was pointed straight.
http://www.youtube.com/watch?v=I8-khaHr52I&feature=mfu_in_order&list=UL
The boring details:
The motor has been going dead lean on the shifts. Still not sure why this is happening but believe the tranny is hitting some kind of limit which signals the ecu to cut fuel. I loaded my new tune re-enableing torque reduction (limits power on shift) hoping it would keep the ecu from cutting fuel. This did help as it was far less noticable but it is still cutting fuel :(. After it cuts fuel it takes some time to recover....not obvious on video but it can easily be felt.
Watch the needle on the wide band gauge on the shift. The 5:00 position is 19 to 1 air/fuel and that is as far as the gauge reads. At full throttle it should remain at the 10:00 position as this is 11.5 to 1.
panda24619
San Diego
UGH! love that sound dude! gives me a woody everytime! yeah thats weird that the gauge dose that. is it cause there is no fuel going into the engine during a shift or is just something the gauge dose?
toms89
toms89
technical advisor
MD
The gauge is accurate...the ecu is cutting fuel?! Datalogging confirmed it just not sure why yet.
Soldier777
tom incredibly sexy... once I burn through my motor I am coming to your house or I will fly you down to help me with this swap.lol
toms89
toms89
technical advisor
MD
your low on washer fluid....lol
Actually I am not. Damn light just goes off every time I drive.:shrug: Just has not been high on my priority list to fix.
Thanks guys for the nice comments!
Just wish I could track down my fuel cut issue...its gonna drive me nuts...:crazy: I know, I know ...as my wife would say :facepalm: "Short trip".
nvycrmn
Springville, IA
well let us know, cuz i am def going to start looking into the swap since i cannot find the s/c that i want. might as well do the swap and go from there!
tallsville
LA
nvy dont forget to stop in colton and pick up the engine block on your way home.
BakerEdition
EF Chaplain
run video
Tom...sounds like the fender gaskets are leaking and the canooten valve may be getting stuck..:joke: Its impressive to watch that speedo climb...now drop it off the jack and lets see what it does....*****.:rotflmao:..Seriously man..its sounds sweet....
toms89
toms89
technical advisor
MD
Have not thought of that. Will have to check my fender gaskets and canooten valve. :rotflmao:
Yeah could not believe how dark the video came out.. Not great with cameras. I will attempt a daylight shot sometime and try and get street view also. Looks faster if you have a point of reference. Would prefer to do after issue is taken care of dont like pushing it when I know it has a problem. Fortunately it appears to be cutting fuel completely which avoids lean related detonation... But for some reason..shutting off the fuel tends to slow it down?!?
panda24619
San Diego
the only thing i can see with why its shutting it down is like in a man trans. let foot of clutch shift foot back on. i dont remember but did lightning come mans?
toms89
toms89
technical advisor
MD
Lightnings came with 4r100 also.. modified version. The odd thing is with lower boost this did not happen. The harder its running the more pronounced it becomes and for longer period of time. I agree it is like the ecu is "getting off the gas" to shift but this is not normal. It will also shift nice and firm at lesser throttle positions and less boost.
JUST4FUN
Admin
Moderator Administrator
Il
i seems like your hitting the rev limiter 5300rpm if you put it in neutral and rev the ball sac off it it will cut out at like 5300 same as in gear need to get/find some way to eleminate this
toms89
toms89
technical advisor
MD
Thats one of the 1st things I checked. The rev limit is set at 6,000 in the tune. There is actually a seperate neutral rev limit but I have it set at 6,000 also. I set shift rpm @ just under 5,400. I raised it over stock due to cam powerband. It could use a bit higher shift point but trying to be conservative.
I have tried several things in the tune with no luck yet but you gave me an idea. I can turn off fuel cut in the tune, only its in the rev limit area?! Might try this and see if it works. I have been focused on finding the cause I did not consider if I could eliminate the symptom..
JUST4FUN
Admin
Il
the symptom is the coputer is shuting the fuel supplie off at lets say 5400rpm
but it will not restart untill it goes below 5100rpm
