Video here: https://youtu.be/f4rwJUthSMU
You may have to turn speakers up, and it's a little easier to hear starting about the 10 second mark as I move the phone farther into the wheel well. But, the noise is like a slight metallic grinding/dragging noise every 3 seconds or so in the video (can hear it pretty good around both the 13 and 16 sec marks.) I'm constantly spinning the wheel. It occurs for about a quarter of the rotation of the hub/wheel, which, with a smaller diameter, is about half the rotation of the inner cv joint. It sounds almost like when brake pads are starting to go and need replacing. My pads are in great shape though and it's definitely coming from farther in, like the inner cv joint area.
I know there's SSM 48082 and TSB 20-2028 related to vacuum lines not releasing out of 4WD all the way. But, noise is present after shutting car off whether left in 2WD or 4WD, unless it would do it in either since car isn't on..??
Having trouble diagnosing it since it's not constant through the rotation. Any thoughts? Thanks.
