Need help ASAP Please
Chris Erickson
Olympia
Just last week i had a very similar problem where my 06 EB would stall when coming to a stop. It would immediately restart but was a struggle to keep it running having to keep the foot on the gas. Once moving it was fine. There was no check engine light on, but the shop found a code for the mass air flow sensor which fixed the problem.
The motorcraft part is very spendy around $200, but there are others out there for less but not sure of their reliability.
Good luck to you!
Habbibie
Habbibie
Is it Christmas yet?
Chicago
Ahhh I just found my leak... Not sure if it's transmission or powersteering fluid... It's too dark to be trans almost like blood red
plumcolr
freehold nj
Look at the trans cooler lines where they go through the plastic clamps / retainers mounted on the radiator support. My lines rusted through at these points and leaked trans fluid.
Habbibie
Habbibie
Chicago
No it's not that far up, it's at the line fittings all the way to the left almost exactly over the front left wheel hub
Habbibie
Habbibie
Chicago
Yep it's transmission fluid, the leak is a shade darker than the PS and matches the trans fluid off of the dip stick
Habbibie
Habbibie
Chicago
Well I think I fixed the trans line leak... I just retightened the connection point (Union). No leaks since but now I'm noticing a small oil leak (engine oil) seems to be coming from the right side of the oil pan... I'll clean it up later and see where it starts dripping again... So many issues since the swap, all thanks to a ford dealer out of all things too
Rooster1978
Tennessee
My first suspect would be the cooler lines running to the radiator. I would start there and work back to the tranny. The rubber lines are prone to cracking and slow leaks over time.
Habbibie
Habbibie
Chicago
Transmission line hasn't leaked in a week so that's confirmed fixed.
Yesterday I redneck style replaced the oil pan gasket, flushed the oil pan with 2 cans of carb cleaner while I'm at it.
Hasn't died or got close to dying since i replaced VCT's & cleaned TB.
And it hasn't bogged down on me since I haven't let it go past 1/2 empty...
Everything is running as it should except for the exhaust leak from the intake manifold but that's a $750+ repair that I can wait on a little longer.
This truck is proving to be more high maintenance than Paris Hilton!
PA
It could be the cam phaser issue which causes the timing to be off, making it stall or run rough at slow speed.
josephbourd
Garden Grove CA
I am having the same problem and now I suspect it IS a bad battery because I notice the lights fade as the engine stalls . I don't think its a fuel problem because it idles just fine in neutral or park and accelerates just fine . I'm going to have my battery checked .
