If you're in Hawaii like profile says then put 5w-40 or 5w-30 or better yet 10w-30 in it.
That should quieten it a little. I use 10w-30 all the time in ford modulars in warm weather and usually but not always go to 5w-30 for cold.
So many people argue about the weight ford made it for or supersedes and currently recommends.
First of all they have other concerns than we do. 2nd there is no way any 1 oil weight EVEN a multigrade can be "best" for trucks in Hawaii and also trucks in Canada.
People say you'll blow the engine, starve it for oil.... I did find one guy saying in warm Temps above 60 lets say, that nothing less than a 40wt viscosity should be used. He was advocating 15w-40 or 5w-40. There's a big difference in those two at temps around 30 though.
I've run them on 10w-30, 5w-40, 5w-30, and mobil 1 15w-50. Got a friend with an old 4.6 leaker that keeps pouring Rotella 15w-40 in and it hasn't blown up in years of that.
But sure, try some thicker oil and see what happens.
He electronics are simple on those to pull an engine.
The harness stays right on the engine. One 10mm bolt on the middle and the car end unplugs from the engine end.
You have to drop but not remove or unhook AC comp, power steering pump/bracket, remove radiator and hoses, fan and belt to pull timing cover anyway.
So from there you only have 2 quick connect fuel lines, 3-4 vacuum lines, power steering reservoir (lean out of way), the 2 exhaust manifold to pipe bolts on each side, the flex plate to torque converter bolts, 2 motor mount bolts (at least on V10 last I did) and 6-8 bolts holding engine to transmission, drop starter and lay on ground leaving wires hooked up.
Get this crap.
I pulled and replaced a V10 in an Excursion without removing hood!
I would have never thought possible.
Had to turn it sideways after lifting up a but to clear better. Same going back in sideways drop it down then spin it.
I did have to pull the intake to get enough height and not hit the hood but I also had a short hoist for the taller SUV. If I would have pulled the hood off I wouldn't have removed the intake early.
