Need Help Please!!!!!
Jjgevf
I have a #03 ford Expedition, Eddie Bauer with just over 200,000 miles on it. It started dying on me at stops and then even while driving down the road. The other day, I drove it to the bank and killed it and went in and when I came out, I wouldn't start. It acted like it was starving for fuel. I added fuel just in case my needle was messed up and still nothing. It turns over but that's it. Tested it and it's showing fuel not getting to the engine. Changed out the fuel pump and it's still not working. Also checked the relay and fuse. What could this be?!?! I don't know what else to check. I know it's not getting fuel?!?!
J
Jjgevf
Tested the relay with one that works and also it fires up with the can of starter fluid.
Bedrck47
Elizebethtown, PA
for one the fuel pump relay is part of the circuit board and isn't normally removable so I question which relay you removed and swapped with another relay
do you have the owners manual
Bedrck47
Elizebethtown, PA
being it fires up with starting fluid you do have spark
when was the last time the fuel filter was changed
also check to see if you have voltage at and after the fuel shutoff switch
stamp11127
Temple, Georgia
Check fuel pressure both static and cranking. If you don't have one they can be picked up at most auto parts stores, online and Sears (where America used to shop).
You should have at least 30 psi. I think the golden figure is 35-40 psi.
You said you tested it and it shows fuel - how and with what did you test it with?
