need help
tangin101
chilhowie va
hey guys I just rebuilt my 98 5.4 1st gen It was a total rebuild. I put the motor back in and after hooking everything up the engine runs smooth like a new one but for some reason the rear heater hoses blew and when you rev the car over 2 grand it blows a big cloud of white smoke and dies.
whats going on with this???????/
cymru
NJ
Could it be that the cats are all clogged and stuff???? I am no expert but a new engine was put in I would not be surprised if you were dumping gas into the cats and they are toast.
T
tangin101
chilhowie va
hook me up
does any one have a diagram I can check my vacuums and coolant hook ups by. I really want this thing fixed me and the wife both loved riding it or a picture of one with detailed shots of were things go
FordandPolaris
Saint Cloud, MN
Well white smoke is usually coolant dumping into the cylinders. The fact that it stalls out says that a lot is getting in. Did you reuse any of the seals...?
T
tangin101
chilhowie va
no i put new everything from rings rods mains from and rear main seals new intake gaskets head gaskets timinhg chains and gasket oil pan gasket valve cover gaskets everything new
cymru
NJ
Off topic but FordandPolaris I posted all those damn pictures after you asked and no response :( Lift, sway bar, track bar and diff cover go on this weekend.
T
tangin101
chilhowie va
help please
ok I took the throttle body assembly off and the lower intake has water in it the lines that connect to the side of the throttle body adaptor one comes from the pcv the other from the temperature sending gauge and the other from the back of the block. so there is water coming threw 2 of these lines correct? if so why is it going straight into the intake is there something of a valve or something missing there.??????????????//
badbolr
