New guy with no turn signals
IMPALADAKID
NH
So my 01 XLT does not have working turn signals left or right. The brake lights work, the 4 ways work. The book shows two locations for turn signal fuses. one at location 13, and one at location 23. Based on the idea that I have brake lights, and flashers, I have ruled out fuse 13. But my truck is not equipped with a lot of the items listed for location 23. So I am going to check that out tomorrow. Do Expeditions have flasher modules? Where would it be located. I just don't want to order a multifunction switch till I rule out the easy cheaper stuff
Thank you
Bill
Bedrck47
Elizebethtown, PA
The expedition has an electronic flasher
It is located behind the dash on the right side of the steering column
The turn signal lamps are never on
Central junction box (CJB) fuse:
13 (20A)
23 (10A)
Circuitry.
Multifunction switch.
Electronic flasher.
IMPALADAKID
IMPALADAKID
NH
can you read and understand wiring diagrams?
Yes I can
13 (20A)
23 (10A)
Circuitry.
Electronic flasher.
Thank you. I assume the 4 flasher is next to it?
Bedrck47
Elizebethtown, PA
prints
  • 90-01.pdf
  • 90-02.pdf
  • 90-03.pdf
  • 90-04.pdf
Bedrck47
Elizebethtown, PA
rest of the prints
  • 90-05.pdf
  • 90-06.pdf
  • 90-07.pdf
IMPALADAKID
IMPALADAKID
NH
Thank you bedrck46. Well tonight I checked fuse 13, and 23. Both are intact. I purchased a new flasher, and plugged it in, and I got nothing. So I guess the next place is to replace the multifunction switch. :emotions122:
