Expedition Dave
Unmounted Nitto Terra Grappler G2 295/70-R18 116S actual dimensions are as follows:
33.6 Height x 11 Width; Tread is 9.75-9.0 inches (depending on what section measured).
For some reason this forum does not allow me to edit my original post when I receive new information, so I will reserve the next post under here to see if airing and mounting makes a measurable difference.
I do imagine when mounted on the rim and aired it should be the same (maybe a smidge taller).
When installed on the truck, I think they will 'squish' down +/- 1 inch at 35 psi.
FWIW, the Michelin Primacys are listed as 32.1 inch tall, but measure 31 inch in the front with 37 PSI of air in them, and 20K miles on them.
