No heat!
B
bedrck46
You need to provide more detail about the problem. Are you getting heat thru the heater hoses? Is the blower running?
G
gmichaels84
Massachusetts
The blower is not running for the front heat. Haven't checked the heater hoses. When I have Vent selected hot air does flow into the truck.
B
bedrck46
always nice to know which year and model you have as there are many differences in the wiring and controls
B
bedrck46
Condition
The blower motor is inoperative—EATC
Possible Sources
Fuse(s).
Circuitry short/open.
A/C blower motor.
A/C blower motor speed control.
Blower motor relay.
Check the following fuses with a meter not just by looking at them
Check Fuse #105 in the battery junction box
Check fuse #2 and #24 in the central junction box
B
bedrck46
I was able to look at your profile to see that you had a 01 EB but many times people fail to say year and model. It always helps to know that information The EB has EATC controls and the XLT has manual controls The wiring is very different between the two.
