No Sound from Entertainment System
The other day the audio system quit producing any kind of sound. It turns on and off. I can hit the mute button and see the visual cue that it's muted. However when I turn the volume knob or use the volume controls on the steering wheel nothing happens. I don't even get an indication on the head unit that I am adjusting the volume. I checked the fuses and every appears fine.
Anyone run in to this? Next stop is the dealer I guess but I don't want to wait forever for them to fix it if I can do something easy. OH. No pending Sync updates either.
-Nick
2021 Ford Expedition Max 4x4 Stealth Edition
NickInTheValley
One other odd piece of info. I just looked at speaker balance/fade and it's stuck at front right. If I move it, it moves itself back.
Rob6805
-Nick
Do you have the B&O system? If so, there is an external amp. Check the fuse for that. Or, it could have failed.
Rob6805
NickInTheValley
Yeah. Checked the fuses for both amps, ACM, etc. All of them. Pulled and replaced. Will do the reset you suggested. Thanks.
Rob6805
The amp may have failed then. Take it in. Warranty will cover it.
2020FordRaptor
Nevada
-Nick
Check the fuse and do a reset. If that doesn't work then take it in to a dealer for warranty work. That's what warranty work is there for.
HazBeen
Great Lakes
Special Service Message 50739 - 2020-2021 Various Vehicles - Audio Inoperative - No Sound From Audio Speakers - No Communication With ACM Or DSP - DTC U1084, U0237 And/Or U0238 - Effective May 3 2022
Some 2020-2021 Escape vehicles and 2021 F-150 / Mustang Mach-E / Expedition / Explorer vehicles built on or before 22-Nov-2021 may exhibit a concern of the audio inoperative, no sound from audio speakers, chimes default to coming through the Instrument cluster, no communication with audio control module (ACM) or digital signal processor (DSP) module, and/or DTC U1084, U0237 and/or U0238. This may be due to the software in the DSP. To correct this condition, perform a hard reset of the DSP by disconnecting the 12-volt battery. Reprogram the DSP module using the latest version of the appropriate Ford diagnostic scan tool. For claiming, use causal part 18B849 and any applicable labor operations in Section 10 of the Service Labor Time Standards (SLTS) Manual.
loganGld
I'm experiencing the exact same issue currently, balance fade stuck on front right and no sound. Did you ever find out the issue?
HILLY
Greenville, SC
Check out the Audio & Electronics forum. I recently went through this and baked my ACM with success.
