no sound from rear left.
panda24619
San Diego
so when i put the new speakers in i really didnt know what i was doing. it worked but still... so i changed the wiring to them not to long ago. all of them worked till all of a sudden the rear left stoped working. so i took out the volt meter and nothing coming threw the wires. i thought it was my deck so i figured ill just get back to it. well today i soldered all my connections and now i have better sound out of the 3 speakers that work and no sound out of the rear left. could i have pulled the wire to much its grounding out or is it connected somewhere in the door i cant see?? idk. im going to get a 4 channel amp one day but until that day comes it kind of bugs now.
kickapebble
Oregon
Since it appears you are savvy with a volt meter, I would suggest disconnecting the speaker, then checking for a signal from the deck. If this doesn't work to well, then cut the speaker wire close to the deck, then do a reading just to make sure it isn't grounded where you can't see it. Good luck.
