stamp11127
On a 12 volt system, 9.1 volts is low.
Isn't the fuel pump relay soldered in? How are you able to remove it? I thought that was only possible on 02 and older relays. Get a new relay, solder it in, should fix your problem for now. 03's were first year for new soldered relays. Most troublesome.
I think you mean model year transition. What she are you talking about? The op is punisher, a male. Can someone that has owned a 03 or newer verify are all the large 5 pin relays soldered in? Or is it just the fuel pump one?
