OBD2 Link EX Cable Does Not Fit
Phil1919
Atlanta, GA
So I got the cable that supposed to work (I have a 2023 Expedition Limited Max), and it seems act like it fits, but it won't push on all the way.
I supported the connecter at the back to not stress it. Still, it would not go on.
Forscan will not recognize the vehicle.
Did I just get a bad cable, or the wrong one? The cable has 2 rows of 8 pins, which matches my OBD2 vehicle connector.
Mr Big
Tampa Bay, Florida USA
When you say cable you are referring to the scanner adapter? I have the OBDLink EX FORScan OBD Adapter and it plugs right in. I also have the Vgate vLinker FS OBD2 USB Adapter for FORScan, which also works.
P
Phil1919
Atlanta, GA
Yes, the adapter (male on one side and USB on the other). It's the EX101 model. None of the pins are bent. Not sure why it won't go on.
Mr Big
All can say is if you are using it for Forscn, get one of the approved OBDLink EX FORScan OBD or Vgate vLinker FS OBD2 USB Adapter. Both work perfect and are automatic switching. Almost all others have issues with writing changes.
No members online now.
rockinghranch
