OEM Roof Top Rack Cross Bar Removal
Shutterbug57
Ohio
I ordered a ‘19 Limited with the cargo package. I expect delivery any time. How easy is it to remove the crossbars on the roof rack? I know the rear bar is movable, but are it and the front bar easily removed and reinstalled when needed? I appreciate your input.
doktoroktobor
Brooklyn, NY
Easy. Just did mine. You need the right size Torx bit, I forget which size. Also helps if you're tall, which I'm not.
Sent from my SM-N950U using Tapatalk
aggiegrad05
North Texas
It’s super super easy. 8 torx bolts and off she comes. The front bar is a little longer than the back, so keep that in mind when reinstalling.
nate6966
US
T30 bit. Very easy. I just pulled mine the other day.
nate6966
US
My front bar was labeled, plus both bars have an indicator as to which side faces front.
mquick5
Buckeye Country
Why are you all removing these, wind reduction?
S
Shutterbug57
Ohio
I like the smooth look better and park in a garage frequently where clearance can be an issue. I bought the bars because I plan to use them on occasion, but I don’t want them on full time.
nate6966
US
As you can tell by my username, I’m an Aggie...labels are really hard sometimes. [emoji6]
I've got a couple Aggie cousins... labels and common sense can be hard, but DANG! They're wicked smart!
aggiegrad05
North Texas
Yes. I like how easily they come on and off. Mine live on the wall in the garage but went on these week to go to the river to tie tubes on. Heck of a vehicle when I can squeeze in 7 folks and strap all our tubes to the roof. Granted, we look like the Beverly Hillbillies if Granny was a river float, but still.
aggiegrad05
North Texas
We’re like 600hp cars with only RWD...lots of power just a lot of trouble putting it all down effectively. Ha!
And thanks for the complement.
mquick5
Buckeye Country
The newer ones must be made differently than my 17. As my cross rails are lower than the side rails.
nate6966
US
Yep. The cross bars on my 19 stick up quite a bit over the rails
Highlightreel
MN
Yes, that front bar is kind of annoying how it blocks the view. Like looking out into the street at a giant telephone pole. I figured it was placed there for strength in case something dropped or hit the roof. Good to know it's ok to either move the front one to the back or just take them off.
Plus, this thing is tall! It's a couple inches taller than my 2009 Suburban was.
nate6966
US
Where would I get those? I don't think I have them.
There were plastic plugs in the center position. I just reinstalled the bolts in the places where my cross bars were sitting. It's on my to do list to find some plugs so I don't lose the bolts.
No members online now.
Landsbutter
