Oh P-0174 WHY will you not go away??
vigman
Valencia Calif
The truck 98 2wd expedition 188K on the clock.
Intake was changed prior to my ownership to the aluminum one YEAH!
The top end was " rebuilt " prior to ownership. The evidence are receipts and FRESH gaskets. Was a Texas truck now California truck so not a rust bucket.. and every electrical connector I have pulled to date doesn't have corrosion in it.
The truck has LOTS of power only a SUPER slight miss at idle W/O ac on ( since the idle is lower ) Codes thrown or not.
Since I have owned the truck this " code "' has popped up at random.. it USED to be on both sides ( Bank 1 & 2 ) but I replaced some vac lines on the vac valves behind the battery that were WAY crunchy. that stopped the bank 1 codes.
Yesterday we replaced the line that goes behind the intake ( engine centerline ) to the pass side PCV and all that multiple 90 deg rubber stuff ( FORD WTH were you thinking when you " designed " that) ? So 1 LITTLE problem I assume the vac port on the rear of the intake is a different OD ( Plastic VS aluminum ) the the O.E. ford " kit " coupler was to large. Not a problem.. on the HELP rack at the local auto parts store is a similar 90 degree fitting for a Chrysler which with a little " magic " ( shrink tube & wire hose clamp ) is BETTER than OE.
Now I know MOST of this is Pass side .. but based on the amount of CRACKAGE on the intake manifold rubber POS fitting that it would help.
BBZZZTTTT Wrongo… after 4 starts the code was tossed.
Observational note.. If I start the truck ( cold morning ) take a long drive 10 miles or more.. let the truck sit for 40 min ( truck is cool again ) and restart, odds are good that the code will not show up.
Hot day running errands… go 2 miles stop , restart, do it again 80% chance I will get a code..
But SOMETIMES it will go for WEEKS with no codes.
If I look at the code scanner there are 4 entries that I think are fuel related
one of the 4 doesn't MOVE ( I'll post a pix later )
So today Drivers side PCV and hose.PLUS close inspection of anything I have missed to date.
BADA BOOM!
Mike
( any thoughts would be appreciated )
JUST4FUN
Admin
Moderator Administrator
Il
Clean MAF ,old fuel filter,or vacuum leak, unmeterd air getting passed the MAF.
Bedrck47
Elizebethtown, PA
P0174 - System to Lean (Bank 2)
The Adaptive Fuel Strategy continuously monitors the fuel delivery hardware. The test fails when the adaptive fuel tables reach a rich calibrated limit.
See Possible Causes for DTC P0171.
For lean and rich DTCs:
Fuel system
Excessive fuel pressure.
Leaking/contaminated fuel injectors.
Leaking fuel pressure regulator.
Low fuel pressure or running out of fuel.
Vapor recovery system.
Induction system:
Air leaks after the MAF.
Vacuum Leaks.
PCV system.
Improperly seated engine oil dipstick.
EGR system:
Leaking gasket.
Stuck EGR valve.
Leaking diaphragm or EVR.
Base Engine:
Oil overfill.
Cam timing.
Cylinder compression.
Exhaust leaks before or near the HO2Ss.
vigman
vigman
Valencia Calif
FPR diaphram , no vac leak.
Dip stick tube AOK
did a wee more inspection and a bit O extra clamping.
Is there support be a hose clamp on the back of the accordion tube ( post MAF ) before it takes the 90 into the throttle body.. LOOKS like there should be…
So we will give it another go … fails again fuel filter
vigman
vigman
Valencia Calif
DPFE ??????
Well today I took her out mid day on a series of variables that SHOULD have made the check engine light trip... It didn't.. it KNOWS I'm watching....
vigman
vigman
Valencia Calif
Day 3 after simple clamping ( see above ) and a extensive maf wire cleaning.... The code has not returned.... Fingers crossed.
vigman
vigman
Valencia Calif
Changed fuel filter today.... OE filter, about 40K worth staining on outside....
Lots of BLACK DEATH coming out the back.......All I can say is it NEEDED IT!
