Oil Change
zmorrow
Houston, Texas
I looked in my owners manual, and for my 2000 EB expo, 5.4L, it says 6 quarts of oil, this includes the oil filter. Well I changed my oil last night, and when I am done changing it, I put the old oil back in the new bottles that are now emptied in the car. I only filled up 4.5 bottles out of 6. Did I put too much oil in my truck?
Zach
wickman
Maple Valley WA
Did you check the oil level before you drained it? You might have been low. Always check the dipstick when you fill it. Overfilling is not good.
ELVATO
Orlando, FL
I always stick in 5, then measure to see how much of the 6th one I need. Most of the time
green03
College Station, TX
The Ford Modular motors are known to use some oil.... you are probably a bit low when it comes time to change the oil....
Matt R
2003expo
Redford, MI
I just had an oil change done at the dealer yesterday. It's hard to tell, but it looks like it is too full on the stick to me. I had the tech check it before I left last night and he said it was because it was just done, but it wasn't like they just pulled it out of the bay and brought it around. We are taking it back in right now to see what they say. It looked to me like it was over the max hole. I would like it under that.
Grasshopper
Moore, OK
That has always been the case with both our 5.4L and the 4.6 in my Thunderbird. 'Tis normal, like it was said before. If it bugs you, check your level every few weeks and add if needed.
I've always added 6 qts with no issues, just like the manual says.
