OIL CONSUMPTION
BUCKSTER
SUMMERVILLE SC
2005 Expy Limited - All Options - Original Owner - 175K miles - Runs great - Regular maintenance - It's ALWAYS "moved" a Qt or 2 of Oil every 10K miles since new but now after last Oil Change w/ my typical 5-20 Full Syn it has fired thru a couple Quarts of Dino 5-30 that I've always used as "add Oil" really fast, like 1K miles - No leaks including valve Covers- No smoke fm Exhaust - Picking up a new PCV Valve today of course but any other thoughts_______?
Flexpedition
midwest
PCV is where to start. I'd look into a compression test either way. A couple quarts of anything in 1K miles is excessive. If you aren't dripping oil then you are burning it, regardless if you see the smoke or not.
Suspect you have a ring stuck or gummed inside its piston groves, which a compression test will show. Have you ever noticed a gasoline smell in the oil you drained out? On any low compression cylinder you can look into removing spark plugs and saturating its pistons overnight in a variety of options. I'd do Marvel Mystery Oil myself. Many concoctions and some are witchcraft, all end with hand turning or bumping the engine a few rotations, then reinstalling plugs, getting it up to normal operating temperature, followed by a fresh oil change. Another compression test on the offending cylinder(s) will tell you if successful or not.
At 175K, its this inexpensive effort or start thinking about a rebuild soon if you elect to keep it.
I've had several new Fords over the years, kept some longer than others, but none have "moved" any noticeable amounts of oil, I've used both conventional and synthetics replacing at the recommended intervals.
B
BUCKSTER
SUMMERVILLE SC
Actually added some Marvel Mystery to Oil last week & I'll run some Sea Foam thru Intake this week - I've had MANY Fords over the years & only this one used Oil between changes fm the git go - Presently have 4 Lincolns, a 2002 Tbird & the Expy - I do virtually all the maintenance on all of them but I'm not touching the Spark Plugs in this thing - They broke 4 when I paid $400 for Spark Plug change at 90K miles - Darn thing runs great... it always loved the cooler ambient Temps, even 70-80 made this thing feel noticeably peppier - & Yeah I always said I'd just buy a new Crate Motor for this thing when the day came - THANX ~!
rjdelp7
2000 XLT
NY
I had a 99 Town Car 4.6l 70K, that did not use a drop in 1000mi. My 2000 Exp 4.6l 103K uses about 1/2 qt every 700-800mi(5w20) and 1/2 qt @1000 mi, using 5w30. Try switching to 5w30 and new pcv. Ford TSB, says 1 qt, between changes is in normal range.
B
BUCKSTER
SUMMERVILLE SC
I wd think 10K on Full Syn 5w20 wd be fine - PCV Valve is inside Valve Cover on 5.4 so just flushed both sides w/some Brake Cleaner & changed Air Filter - Used 1 qt Non Syn 5w30 in 2K miles of fast lane Interstate driving - I can live with that with 180K miles on motor.
