Oil/Coolant lamp comes on and off - Gauges show normal pressure
TobyU
Ohio
We have a 2000 with 250k that has done that on and off since 215k or so.
Scared me at first but once i realized it had pressure I didn't worry about it.
I started only doing on cold start on in the first 5-10 minutes.
I changed the oil a few times sooner than normal (always used mobil one 5w-30) and it stopped for a while, then started doing but only a little bit.
I think it just has some dirt in the sensor but I'm too lazy to change it and its hard to get to on the 4x4 with 5.4.
P
Petesexpy
Delaware
Yeah, it took me 2 hours to replace the sensor. It could not be in a worse location...
P
Petesexpy
Delaware
By the way, my 2000 has 220K miles. I had the entire rear subframe with body mounts replaced (at cost - the local guy took pity on me and it was still $1,560) due to rust. The next one is the radiator support, if I can get it fixed for less than $1,500...But everything else works fine...after I spent $500 on intake manifold gasket replacement.
