Deadman
I'll try some smoky burnouts with mine one of these days to see if the babysitter can be fully shut off and I'll see if the locker works as its supposed to on dry roads assuming it'll overcome the abs bs!
i wanted the navi for those seats. best seat execution I've ever seen. one of the preschool moms has one and its sweet. but the lack of a true two speed tranny kills it for me
I wish I had a differential lock button. I have a 2wd with the tow package, so I should have the eLSD. I didn’t want to have a one wheel wonder at a boat ramp.
Does it act different depending on the driving modes?
What is a good method to test the eLSD?
The differential in the video below looks very similar to the parts page posted before.
I believe so. I normally pull my boat out of the water in 4wd, but I don't slip when I forget. I have slid slightly on freshly wet pavement in 2wd on a corner. Changing to 4wd normal mode eliminates the problem. So, when it is rainy, I use 4wd normal mode.If you have an 18MY or newer with the HDTT, you have the eLSD with a locker. When pulling the boat out of the water, the eLSD will give the wheel with the most traction the torque.
You know the Navi has the same trans as the expy right? Except Navi BL comes standard with heavy duty tow package.
yes the transmission is the same but i don't believe you can get a navigator with the two speed transfer case.
Just think of the money you saved...that's pretty cool. i couldn't find any info on that when i was looking to buy my expedition. even when i went to build one on lincolns website i couldn't find any info on if it had the two speed. i tried googling it before i posted that too and still couldn't find any info. that's something i would have thought they'd advertise. the only reference to having two ranges didn't specify low range so i assumed they must only have 4a and 4h. probably would have looked harder for a navi if i had known that. the interior on the navi is so nice
Sure you can, I own one.yes the transmission is the same but i don't believe you can get a navigator with the two speed transfer case.
TFL issues were that it disables when you turn the Truck off. Andre turned Truck off and got out, then got back in and forgot to Turn it back on. He got blasted for it too!!!
I love TFL.
I do too. Roman and his team are great.
They have a denali beating a Navi in a race but I still like them!
I think if they did it 3 times, the Navi would have won 2 times. There is also the factor of what fuel they put in it?
Yeah, that video perplexed me. They were close. I think if they did it 3 times, the Navi would have won 2 times. There is also the factor of what fuel they put in it?
