One Touch Windows Don't Work When Cold
BrianDA
Georgia, United States
Anyone having problem with front D&P windows one touch not working of below about 40F? Almost like the seal is too tight? Sometimes the driver's window will stop about 3/4" from the sill even if it's about 60F. Other times it works fine. Only 6000 miles, maybe the seals need to "stretch in"?
wakeboarder
Fort Lauderdale, FL
I think there is a calibration procedure for the window motors. I seem to remember having to do it after I installed my AVS window shades. I would perform it when it is cold out.
m3olsen
CNY
Found a couple different methods online. Tried one. Bring on the cold!
Brian,
Which method did you use? I'm having a similar issue when it gets really cold.
Thanks.
@BrianDA I'm curious too. I don't roll down my windows often and realized yesterday my driver window faults out when going up and kicks the window back down. I have to coax it through the last inch of rise to get it to close. I'm sure it worked fine back in the Fall.
sharprd65
