P013A Code 2013 Expedition EL
superdave83
Onslow County NC
Check engine light just came on for my 2013 EL 5.4L 3V, P013A O2 Sensor Slow Response - Rich to Lean Bank 1 Sensor 2. Anyone had any experience with this code with their 3rd generation? I was thinking to just replace the downstream sensor is the best guess to fix. However I did see that potentially the fuel injectors might have something to do with it. My scanner says the likely problem is an exhaust leak. Any advice is appreciated.
Mjhcobra
Tucson, Arizona
I had the same issue with our 2015, but bank 2 sensor 2. I bought the sensor and then checked the scanner again and the code was gone and no engine light. I guess that is what is meant by "slow response".
S
superdave83
Onslow County NC
Good to know. Do you remember which brand of sensor you bought? I am guessing Motorcraft would work best, but people also tend to have good experience with Denso brand. Thank you for the reply Mjhcobra
tifanydire
