P0171 and P0174 Bank 1 & 2 lean
Broncoholic
Space Coast, FL
Guess I'm getting a smoke machine! My '03 5.4 has been running great, but set 4 codes yesterday - P1000, P0171, P0174, P0442. I expected the 442 since I've had cracked plastic fuel tank fittings for years, but the lean conditions are new and point to a new vacuum leak. I have mostly original vacuum lines in the engine bay.
Broncoholic
Space Coast, FL
Popped the hood and think I found the leak in 2 seconds without getting dirty or taking the smoke machine out of the box. Gonna see if this hose is still available OEM.
Broncoholic
Space Coast, FL
2' of 3/8" fuel line with a dab of oil on each end to help it slip over the barbs. Unfortunately the clips on the green elbow were brittle and broke off. It's a snug fit at the valve assembly so I don't think it'll fall off, but I may add a zip tie around the whole thing to ensure it doesn't slip off.
Broncoholic
Space Coast, FL
I used the Dorman replacement and found the hose to be higher quality than the OEM hose. It's been on there for about 8 years and no sign of deterioration . I don't know why Ford used such crap material for their vacuum hoses, but they did.
Dorman Replacement Evap Vapor Vacuum Hose on Amazon
I looked at that, but all the fitments said it wasn't for 2003 Expy. I figured, if I'm buying something that isn't made to fit, I'll just go the cheap route and buy bulk fuel line.
Hamfisted
Ft Lauderdale
Yeah, sometimes Amazon's fitment charts are off. But it fits and is a direct replacement.
