CEL came on a week after removing my throttle body to clean it, code P0446.
- No vacuum leaks
- Verified evap canister vent valve is functional
- No clogged or damaged hoses to/from evap canister
- Checked voltage at harness to vent valve. Begins at 9.5v and drops to 0v within 10 seconds. I don't know what that means. Should be 12v constant with key on.
- Have not proved the purge valve under the hood is working or if it gets 12v
- If I fill my tank till the pump stops it will spit out a quart or two of fuel. It's done this for at least 50,000 miles. Never had evap code before.
- I now have a very rough idle when I start the exp in the morning. No changes in rpm but it shakes for a minute. I think it's sucking vapor not fuel. Then once the air is purged it runs normal.
Interested in feedback regarding the drop in voltage at the harness and any possible fixes.
- No vacuum leaks
