Park override switch?
ARiley23
Truck won't come out of park and need to move it. Is there a way to override it so I can get it into gear?
Sent from my SM-G935V using Tapatalk
juan214
Stoughton, MA.
did you do this as instructed the other day?
Do this at your own risk: Looks like you have the two wire connection (w/o power petals).
  • Bypass brake switch
  1. Pull harness
  2. With a 20 amp or less fuse and fuse holder jump the connector. Connect one end to powered lead and the other to the brake light lead.
Your brake lights will be activate and selector should be unlocked and move. If the fuse blows there is a short in the system
